It is currently Tue Nov 17, 2026 7:01 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Sat May 04, 2002 3:22 pm
Hey Andrew and everybody,
I hope the racing was on this weekend (rain?) at Mason Dixon, and that you had a blast and the new motor was strong.
One question about those Conquest wheels (16X7, 5" backspace): Did you have to run any wheel spacer in the front so that the wheel does not hit the upper ball joint? On my Dart (same spindle/brake geometry as yours) it looks like the inner rim edge might rub on that BJ with 5" backspacing. Just curious.
Feel free to email me back and I'll post the response here, or you can respond here.
Thanks very much,
lmadsen@email.unc.edu
PostPosted: Sun May 05, 2002 4:42 am
No I did not have to. At frist it looked that way but it clears. I will take a pic and post it tonite. and I will be at the races today.
andrew wagner
: Hey Andrew and everybody,
: I hope the racing was on this weekend (rain?)
: at Mason Dixon, and that you had a blast and
: the new motor was strong.
: One question about those Conquest wheels (16X7,
: 5" backspace): Did you have to run any
: wheel spacer in the front so that the wheel
: does not hit the upper ball joint? On my
: Dart (same spindle/brake geometry as yours)
: it looks like the inner rim edge might rub
: on that BJ with 5" backspacing. Just
: curious.
: Feel free to email me back and I'll post the
: response here, or you can respond here.
: Thanks very much,
: Lou
PostPosted: Sun May 05, 2002 9:52 am
: No I did not have to. At frist it looked that
: way but it clears. I will take a pic and
: post it tonite. and I will be at the races
: today.
: andrew wagner
We can't wait to hear how your new engine / turbo set-up runs. Best of luck!
(I'm alway on edge with new engine set-ups, I've had too many go boom on their first time out to the track : - (
(then again, most of those have been "never done before" combos . . . live and learn!)
PostPosted: Sun May 05, 2002 1:17 pm
I tried to use that size wheel - same backspacing and all - on my '66 with '79 Newport brakes. It looked all right in the air, but when it came off the jackstands it scraped so badly I could barely move the car. And that was with 1/4" spacers. I would be cautious.
PostPosted: Mon May 06, 2002 5:11 am
: I tried to use that size wheel - same
: backspacing and all - on my '66 with '79
: Newport brakes. It looked all right in the
: air, but when it came off the jackstands it
: scraped so badly I could barely move the
: car. And that was with 1/4" spacers. I
: would be cautious.
Matt,
Thanks for your response. Which spindles and brakes did you use? Are the spindles the '73-76 Dart units and the brakes the 11.75" B-body rotors?? Or, did you use spindles from the Newport or some other car?
Thanks very much,
PostPosted: Tue May 07, 2002 3:08 pm
This setup uses the '73-'76 A-body spindles, upper control arms, and ball joints.
