It is currently Sat Aug 15, 2026 3:32 am
PostPosted: Wed Jun 03, 2009 5:05 am
I'm trying to determine if my 65 Dart is a 225 or 170. I tried the VIN, but with no success, it just told me it was a slant six.
I'm having a tough time nailing down the engine stamp number. Do you know of any complete listings of engine stamp numbers?
PostPosted: Wed Jun 03, 2009 5:20 am
measure the 5/8" water hose running between the top of the water pump and head. If it is about 3 1/4" long you have a 225 ci., if it is around 2 3/4" long you have a 170 ci. engine.
The 170 block is not as tall as a 225 block.
PostPosted: Wed Jun 03, 2009 8:55 am
The engine ID number is stamped on a ledge at the top of the block, below the frontmost spark plug, just inboard of the alternator/coil bracket. You may need to scrape or wipe away grease and grime to find the stamping. If your engine is original, the stamping will start with an "A".
The engine block casting number is on the manifold side of the block, near the freeze plugs. Tell us what you find in both locations and they can be decoded.
PostPosted: Wed Jun 03, 2009 8:08 pm
Casting is 2806830-3
Water hose is about 3"....
Let me know what you think.
Can I not get to the EIN without taking something apart?
I'm hoping its a 225.
PostPosted: Wed Jun 03, 2009 8:09 pm
Also, where can I find date and time stamps on my engine? Wondering when it was built.
PostPosted: Wed Jun 03, 2009 9:00 pm
It's a 68 thru 75 225. (based on the block's casting number)
PostPosted: Wed Jun 03, 2009 10:53 pm
Who said anything about taking anything apart to read the stamped numbers? :shrug: :?: Go read the numbers — go ahead and give it a try — and then we'll be able to tell you when your engine was built.
PostPosted: Thu Jun 04, 2009 5:19 am
Sorry SlantSixDan,
I did read the casting number, but couldn't find the EIN, so I did "go ahead, and give it a try." Doctor Dodge was kind enough to give me a straight answer. Sorry I'm new at this, and that bothers you. I'm just trying to learn as much about my car, and engine as I can.
PostPosted: Thu Jun 04, 2009 5:39 am
There are photos of the pad where the numbers are stamped HERE
Let us know what is stamped there. If the deck has been shaved, the numbers may not have been restamped.
PostPosted: Thu Jun 04, 2009 5:45 am
Exhibit: "A"
I could not read any numbers from the top of the block near the fuel pump & plug #1 on my engine. When I removed the head this winter there were none in that location, they most likely had been removed during a trip to the machine shop.
PostPosted: Thu Jun 04, 2009 5:54 am
Thanks guys,
The photos were very helpful. I'll check it out when I get home tonight.
PostPosted: Thu Jun 04, 2009 10:25 am
C'mon, dude, gimme a break. I'm not bothered by your being new, I was mystified by your apparent disregard for a pointer directly to the stamping number that would tell you everything you want to know about when exactly your engine was built. It was an attempt to help you.
PostPosted: Thu Jun 04, 2009 11:03 am
My mistake then I guess. Thanks for your help. I just didn't know where the alternator/coil were. I'd still like to post the EIN when I get it.
PostPosted: Thu Jun 04, 2009 11:21 am
Ah, okeh, I was assuming you would be able to identify those components on sight. They're at the right front corner of the engine. Find the fan belt and see the frontmost-rightmost component it drives. You'll see the finned, round aluminum housing of the alternator. Rearward of the alternator is the ignition coil, which has two or three small wires and one central large wire connected to it. Also take note that there are six spark plug wires, each of which connects at one end to the distributor cap (where the other end of the coil's large wire also connects), and the other end of each spark plug wire goes to a spark plug. There are six spark plugs in a row, front to back. Start at the alternator and look rearward, start at the frontmost spark plug and look downward, start at the ignition coil and look slightly upward, and you should arrive at the engine stamping number.
You'll want to get these three books as quickly as you can. They're cheap and worth their weight in gold. They'll get you up to speed in an easy hurry on how to identify your car's components, how they work, and how to service them.
PostPosted: Thu Jun 04, 2009 11:27 am
Thanks Dan,
I have the two books from Amazon in the mail, and am in contact about the mopar factory book :) Can't wait for them to get here.
65 Dodge Dart 270 Convertible
