| Holley 1920 Vent Valve problem https://slantsix.org/forum/viewtopic.php?t=35690 |
| Author: | demonguy71 [ Thu Jun 04, 2009 5:16 pm ] |
| Post subject: | Holley 1920 Vent Valve problem |
Is there supposed to be a spring under the mechanical vent valve on the holley 1920 carb? My Vent valve is always down and I had pulled the cover off & did not see a spring. If the rod is supposed to push that valve down, how can it do that when the valve is never up? |
| Author: | HardCharger [ Thu Jun 04, 2009 5:39 pm ] |
I don't know what it looks like inside (spring or?) but it should pop up and be within I think .015 of the bottom of the spring loaded rod that goes under the choke pulloff. |
| Author: | Aggressive Ted [ Thu Jun 04, 2009 7:03 pm ] |
Yes, Mine has one under the vent. Is has about 3 or 4 turns. |
| Author: | SlantSixDan [ Thu Jun 04, 2009 11:06 pm ] |
What year carb are you working on? |
| Author: | DynoDave [ Fri Jun 12, 2009 6:27 pm ] |
Any updates on this? |
