It is currently Tue Nov 24, 2026 12:38 pm
PostPosted: Thu Jun 04, 2009 5:16 pm
Is there supposed to be a spring under the mechanical vent valve on the holley 1920 carb? My Vent valve is always down and I had pulled the cover off & did not see a spring. If the rod is supposed to push that valve down, how can it do that when the valve is never up?
PostPosted: Thu Jun 04, 2009 5:39 pm
I don't know what it looks like inside (spring or?) but it should pop up and be within I think .015 of the bottom of the spring loaded rod that goes under the choke pulloff.
74 Dodge Charger 225 factory A/C auto 1920 carb stock exhaust.
Mods;
HEI, MSD B3, Magnecor 8 mm, ZFR5N, .060 rotor, CH410X cap, new 3874814 dist, fuel mod, valves hot .010 & .020, all new hoses, JP chain, brake hoses and fluid.
PostPosted: Thu Jun 04, 2009 7:03 pm
Yes,
Mine has one under the vent. Is has about 3 or 4 turns.
PostPosted: Thu Jun 04, 2009 11:06 pm
What year carb are you working on?
PostPosted: Fri Jun 12, 2009 6:27 pm
Any updates on this?
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
