It is currently Wed Nov 11, 2026 8:27 am
 Post subject: rp6408 bearing install
PostPosted: Sat Jun 13, 2009 9:35 am
Ok call me dumb but I want to get this right before I start whacking on this new bearing.
I bought the rp6408 repair bearings for my 8.25 rear end's to try and fix some noises coming from the wheel bearings. The install instructions say install with the seal facing out but it has two seals. The bearing looks like it tapers down and fits in with the smaller seal going into the axle housing first. From the pic the seal side show would appear to go into the axle shaft first yes? The other side is a bit larger in diameter and I don't think it will press into the housing.
Arizona Duster in Canada
 Post subject: Never Mind
PostPosted: Sat Jun 13, 2009 8:17 pm
Never Mind I figured it out. The side you see in the picture goes into the axle housing first.
Another fine project done......on to the next
