It is currently Tue Nov 17, 2026 9:14 am
 Post subject: adjustable rocker arms
PostPosted: Wed Jun 24, 2009 8:31 am
I own a 1966 plymouth valiant signet with a 225 slant six , modified as per hotrod magazine article "slant sickness" my problem is my adjustable rocker arms are worn out , no running torque on a few adjuster screws, (loose). I have to keep regapping every so often. I have worn out my fingers checking sites for replacement originals and thought of going to adjustable roller rockers but no luck. Am I stuck going to the junk yard ?
Steve
PostPosted: Wed Jun 24, 2009 9:11 am
Welcome on the board. There are a few ways of addressing this issue. See the valve adjustment article. There's also at least one outfit selling rebuilt rocker shaft assemblies with good rockers: http://www.rockerarms.com
PostPosted: Wed Jun 24, 2009 10:34 am
I have a bunch of good used SL6 rocker arm assemblies, if you want to go in that direction.
PostPosted: Wed Jun 24, 2009 2:09 pm
What about adding a jam nut?
PostPosted: Fri Aug 21, 2009 9:21 am
Just picked up new adjustable rocker arms from Kanter. Works great. Problem solved
Steve Morin
66 Plymouth Valiant Signet
2 Dr Hardtop
(Slant Sickness)225 Hyperpack, 4 bbl 500cfm edelbrock, A904, 7 1/4 Suregrip
