adjustable rocker arms
https://slantsix.org/forum/viewtopic.php?t=35980
Author:  crazybazz [ Wed Jun 24, 2009 8:31 am ]
Post subject:  adjustable rocker arms
I own a 1966 plymouth valiant signet with a 225 slant six , modified as per hotrod magazine article "slant sickness" my problem is my adjustable rocker arms are worn out , no running torque on a few adjuster screws, (loose). I have to keep regapping every so often. I have worn out my fingers checking sites for replacement originals and thought of going to adjustable roller rockers but no luck. Am I stuck going to the junk yard ?
Steve
Author:  SlantSixDan [ Wed Jun 24, 2009 9:11 am ]
Welcome on the board. There are a few ways of addressing this issue. See the valve adjustment article. There's also at least one outfit selling rebuilt rocker shaft assemblies with good rockers: http://www.rockerarms.com
Author:  Doc [ Wed Jun 24, 2009 10:34 am ]
I have a bunch of good used SL6 rocker arm assemblies, if you want to go in that direction.
Author:  emsvitil [ Wed Jun 24, 2009 2:09 pm ]
What about adding a jam nut?
Author:  crazybazz [ Fri Aug 21, 2009 9:21 am ]
Just picked up new adjustable rocker arms from Kanter. Works great. Problem solved
