It is currently Fri Nov 13, 2026 8:48 pm
 Post subject: Alternator
PostPosted: Tue Jun 30, 2009 6:12 am
Hey everyone.. I'm pretty sure my alternator is junk. Does anyone know where to pick up a cheap alternator?
-- Mister Perkins --
Pictures of my truck
http://www.cardomain.com/ride/3257131p
PostPosted: Tue Jun 30, 2009 7:07 am
Sure, you can pick up a cheap "remanufactured" alternator at your nearest parts store. Then you get to change it again and again and again as they fail in sequence.
Did you really mean you wanted a reliable replacement alternator?
PostPosted: Tue Jun 30, 2009 7:57 am
You can pick up a reman alternator at your local parts store for fairly cheap. A more long-term alternative would be to take your alternator to a good shop that rebuilds alternators and starters.
'78 Volare 225
'67 Charger 318
PostPosted: Tue Jun 30, 2009 9:23 am
went to the salvage yard and picked one up for free from a buddy. Noticed the voltage regulator wire was disconnected too, so I think that was the main cause to the problem. Its cranking plenty of voltage back to the battery now though, so hopefully this alternator doesnt go out right away!
PostPosted: Wed Jul 01, 2009 5:56 pm
Dan
what is a source for reliable, replacement alternators?
thanks
