| Alternator https://slantsix.org/forum/viewtopic.php?t=36035 |
| Author: | Mister_Perkins [ Tue Jun 30, 2009 6:12 am ] |
| Post subject: | Alternator |
Hey everyone.. I'm pretty sure my alternator is junk. Does anyone know where to pick up a cheap alternator? |
| Author: | SlantSixDan [ Tue Jun 30, 2009 7:07 am ] |
Sure, you can pick up a cheap "remanufactured" alternator at your nearest parts store. Then you get to change it again and again and again as they fail in sequence. Did you really mean you wanted a reliable replacement alternator? |
| Author: | Wesola78 [ Tue Jun 30, 2009 7:57 am ] |
You can pick up a reman alternator at your local parts store for fairly cheap. A more long-term alternative would be to take your alternator to a good shop that rebuilds alternators and starters. |
| Author: | Mister_Perkins [ Tue Jun 30, 2009 9:23 am ] |
went to the salvage yard and picked one up for free from a buddy. Noticed the voltage regulator wire was disconnected too, so I think that was the main cause to the problem. Its cranking plenty of voltage back to the battery now though, so hopefully this alternator doesnt go out right away! |
| Author: | DadTruck [ Wed Jul 01, 2009 5:56 pm ] |
| Post subject: | Reliable Replacement Alternators |
Dan what is a source for reliable, replacement alternators? thanks |
