It is currently Sat Nov 21, 2026 11:31 pm
 Post subject: Weber Carb Info
PostPosted: Sun Jul 05, 2009 1:17 pm
Picked up a Weber from the Huntsville show.
Markings are 32/36 DGAV-3381 30-6A
Any idea on the CFM etc. Looks like it would be a chore to swap this on to a slant!
It doesn't open the secondaries all the way.
Thanks in advance!
PostPosted: Sun Jul 05, 2009 1:58 pm
Have a pictures?
The secondary will OPEN up completely if the bushings and linkages wear are in GOOD condition. Parts are plentiful.
That means no play in bushings and linkage correctly done. That is what I need to see in pictures especially the linkages.
Sufficient to do a 225. :)
Cheers, Wizard
