It is currently Fri Apr 24, 2026 8:13 am
PostPosted: Tue Jul 28, 2009 7:33 am
I am going to switch from a single master cylinder to duel for obvious safety reasons. I have a 1964 Valiant with front and rear drums which I will keep. What year mopar should I buy the duel cylinder for that will best fit my 1964? Seems like a pretty easy change but if you think of any problems i may encounter I would appreciate the input..thanks Mark
PostPosted: Tue Jul 28, 2009 10:53 am
1973 Drum brakes works.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Jul 28, 2009 3:17 pm
You might have trouble finding the correct fitting for the front port on the master cyl. It is a 9/16-20 thread. I have been unable to find a fitting in any parts store. I did find a vendor and have some on hand, They are not an adapter, but go right on a 3/16 brake line. Sometimes you can find theses fittings in the junkyard, and cut the old line and install them on your new line.
PostPosted: Tue Jul 28, 2009 6:55 pm
You can also get a master Cyl Line set from Right stuff or fine lines. 67-76 A bodies Either Drum or disc will be thesame on these lines with the correct port / adapter sizes.
 Post subject: duel master
PostPosted: Wed Jul 29, 2009 6:16 am
Thanks guys. Charrlie Ill get with you on the part if you have one to sell that would work..thanks again
