It is currently Mon May 11, 2026 3:24 pm
 Post subject: engine swap questions
PostPosted: Wed Jul 29, 2009 11:16 am
i have a 72 dart /6 i bought a 65 /6 the other day to replace the worn out 72. will my power steering pulley bolt to the 65 crank pulley? will the 904 bolt up to the older flex plate?
65cuda 360, 71 Duster 416 11.84@110mph , 72 dart 440, 72 dart /6, , 71 Dart /6 2000 Kota, 73 Imperal,
Legendary Dealer
PostPosted: Wed Jul 29, 2009 8:28 pm
The PS pulley will bolt on, but you have a bigger problem. The 72 torque converter "nub" will not fit the hole in the end of the 65 crank.
The diameter of the crank register got larger between 67 and 68. You cannot use the 65 converter in the 72 trans, because the diameter of the trans input shaft also got larger, between 67 and 68. The onlty tqo options are to put a later crank in the engine, machine the end of the crank larger, or use a custom converter, with the small "nub", and large input splines.
PS: putting a later engine in a early car is easy, but a early engine in a late car has major problems.
PostPosted: Thu Jul 30, 2009 8:31 am
well crap. if the crank is good in my 72 would it just bolt in the 65 block? i could do that esay if it would fit. there is a converter shop in town i guess i could see what that would cost?
i will have to regroup i was going to do the swap today.
Legendary Dealer
PostPosted: Thu Jul 30, 2009 9:31 am
well crap. if the crank is good in my 72 would it just bolt in the 65 block? .
Yes, if both engines are 225's. The 65 might be a 170, you will have to check. You will also have to check that the 72 encine is a 225, and not a 198.
PostPosted: Thu Jul 30, 2009 9:52 am
well i think they are both 225s the 65 motor came out of a b body. the vin on my dart says 225. but it has been messed with. i think someone added a super six set up to it. so its a bolt in if they are both 225s. i like that. now if the crank is ok in the 72. i think it is. it's still running but sounds like a wrist pin is knocking. won't know till i tear it down. i know there is an article on here somewhere to tell for sure what ci they are. i will search for that.
Legendary Dealer
Users browsing this forum: Google [Bot] and 9 guests
