It is currently Thu Nov 19, 2026 3:11 pm
PostPosted: Fri Jul 31, 2009 11:19 am
I have a 64 auto dart with the bushbutton shifter. I have noticed, that when warm, it doesn't want to go into reverse. The button will not go in. I haven't had the car long, but is that a problem with the buttons or an adjustment needed to the trans end of the cable, or something worse?
 Post subject: sticky buttons
PostPosted: Sun Aug 16, 2009 7:28 pm
Last summer my 63 valiant the reverse button stuck Went and talked to the local transmission man also a mopar man :D :D
There is a valve in the valve body int the trans that's called an idiot valve to keep some idgiot from reaching up and pushing the reverse button while driveing 55 mph down the road to keep from stripping the gears this valve was barely stuck in mine didn't want to go into reverse and the button wouldn't engage, pretty easy to fix if you feel comfortable with hand tools. :wink: GET A NEW TRANS PAN GASKET Take the pan off, draing trans fluid then take off filter if equipped also a good time to repace if any doubt, Take down the valve body there will be a small round valve popped up take a rag and wipe off all the fluid sqirt a little oil or penatrating oil on it and work it up and down several time put the valve body back in place and reasmemble, I done it over a year ago myself no problem's since
PostPosted: Mon Aug 17, 2009 5:19 am
NOTE I have heard to use an oil rated for Trans if not then you will contaminate your fluid and could damage it. They DO make lube and penatrating oil just for the trans.
Just my 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
