It is currently Fri Nov 13, 2026 6:57 am
PostPosted: Sun Aug 02, 2009 6:09 pm
The emergency flashers on my 69 Valiant aren't responding. All the other lights and turn signals work. Fuse checked out ok, but no power seems to be getting to the switch. Where is the flasher unit?
Thanks,
Travis
PostPosted: Sun Aug 02, 2009 7:00 pm
A little tin top hat located between the steering column and radio under the dash.
Is your switch a toggle located on the face of the dash, or the newer steering column mounted pull-out type located near the ignition key? I have forgotten which year the ignition key & four way switches were relocated.
PostPosted: Mon Aug 03, 2009 5:08 am
Well I've got the toggle type on the dash but my big challenge is going to be the facory ac unit which appears to be right in the way. Thanks for the info!
Travis
