It is currently Sun Nov 15, 2026 10:21 pm
 Post subject: porting question again
PostPosted: Mon Aug 03, 2009 1:56 pm
ok i was compairing my gasket on the intake to the head the head was dead on but...
<a href="http://s648.photobucket.com/albums/uu204/joshhuskey/?action=view&current=IMG_0980.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu204/joshhuskey/IMG_0980.jpg" border="0" alt="Photobucket"></a>
<a href="http://s648.photobucket.com/albums/uu204/joshhuskey/?action=view&current=IMG_0981.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu204/joshhuskey/IMG_0981.jpg" border="0" alt="Photobucket"></a>
<a href="http://s648.photobucket.com/albums/uu204/joshhuskey/?action=view&current=IMG_0982.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu204/joshhuskey/IMG_0982.jpg" border="0" alt="Photobucket"></a>
should i port the intake?
and also yall said to do more pocket porting
before
<a href="http://s648.photobucket.com/albums/uu204/joshhuskey/?action=view&current=IMG_0952.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu204/joshhuskey/IMG_0952.jpg" border="0" alt="Photobucket"></a>
after
<a href="http://s648.photobucket.com/albums/uu204/joshhuskey/?action=view&current=IMG_0991.jpg" target="_blank"><img src="http://i648.photobucket.com/albums/uu204/joshhuskey/IMG_0991.jpg" border="0" alt="Photobucket"></a>
is this more acceptable?
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Mon Aug 03, 2009 2:12 pm
I wouldn't port match the intake unless the head is opened up to the same size. A small step bigger going in the direction of the gases is not a bad thing. I would clean up imperfections like large casting bumps in the intake as far in as you can reach. By leaving the surface slightly rough it will help turbulate the air for better atomization, but heat is your best friend when running rich.
PostPosted: Mon Aug 03, 2009 2:37 pm
the intake ports on the head are mached with the gasket perfectly, but it was like that from the factory so should i port it
PostPosted: Tue Aug 04, 2009 12:03 pm
Sounds like some one already did some port work on the intakes on your head. Normally there are always irregularities and a mismatch. Since you are so fortunate, you can try and match the intake manifold. Use a real long reamer so you can go as far as you can inside the intake to create a very gradual taper. Just doing a bell mouth gasket match won't do a thing for the flow.
PostPosted: Wed Aug 05, 2009 6:44 am
Your pocket porting is looking good.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
