Another horn problem
https://slantsix.org/forum/viewtopic.php?t=36713
Author:  73NorthernDuster [ Wed Aug 12, 2009 1:29 pm ]
Post subject:  Another horn problem
Ok the horn on my 73 Duster used to work just fine. Now for some reason it has stopped. I've tried the tests in the FSM at the relay. When I put a wire between the #1(fuse) socket and the #3 horn socket the horn blows. When I put a wire between the #1 and #2 (horn switch) and press the horn switch it blew the fuse.
I pulled it all apart and it looks just like when it worked. It has to be either the relay or a wire between the relay and the switch but if that were the case I wouldn't think it would blow the fuse (power must be flowing right?) But the FSM says if the horn doesn't blow it's the switch or wiring.
FYI I have a grant aftermarket wheel on but like I said it worked fine a few weeks ago. ARGHHHH!
Any thought appreciated....
PS hope to see some of you on the weekend at moparfest!!
Cheers
Brent
