| Rod Info Needed https://slantsix.org/forum/viewtopic.php?t=3673 |
| Author: | Arthur Hutchison [ Fri May 24, 2002 4:53 pm ] |
| Post subject: | Rod Info Needed |
I received my Rods today that are supposed to be 198 Rods.The #1947167 is on the side of the Rod & #65 on the other side.Can someone tell me what Rod i have ?,it does not measure 7" center of piston pin to center of Rod ,more like 6"..........arthur coinjockey@webtv.net |
| Author: | Doc. [ Fri May 24, 2002 5:34 pm ] |
| Post subject: | Re: Rod Info. & 170 Rods |
: I received my Rods today that are supposed to : be 198 Rods.The #1947167 is on the side of : the Rod & #65 on the other side.Can : someone tell me what Rod i have ?,it does : not measure 7" center of piston pin to : center of Rod ,more like : 6"..........arthur That is the 170 forging number, these should be 5.7 inches long. Al's revised table has this info. (see the link) (We did find a way to convert this table into a small printable file so we will add it to the article section once Chuck returns) DD Al's SL6 Application Table |
