It is currently Fri May 15, 2026 2:28 pm
PostPosted: Wed Aug 19, 2009 6:24 am
Why does the size of a converter matter? Is it the weight and how fast it can be spun? I here guys say 8". 9", 10",etc.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Aug 19, 2009 9:56 am
In general, the smaller the size, the higher the stall speed you get, with good efficiency.
You can get larger converters to stall at higher rates but they are not as efficient, making a lot of heat in the process. Most of the "low cost" high stall converters that are in the larger factory shell sizes have been cut open and had their inner vains "bent" in a way that makes them stall higher but doing that does not transmit all the power thru the unit.
PostPosted: Wed Aug 19, 2009 6:04 pm
Doc
So I here the guys talk mostly about 8" converters. They would be high stall purpose build.
So for the FED I will look for an 8".
Thanks,
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
