It is currently Fri May 08, 2026 3:51 pm
 Post subject: Front End Noises
PostPosted: Mon Aug 31, 2009 12:54 pm
HI, COMPLETED A FRONT END DISC BREK CONVERSION FROM A LATER MODEL F BODY. REPLACED ALL THE BEARINGS, DISC, PADS ETC. ALSO REPLACED THE UPPER CONTROL ARMS, BUSHINGS,BALL JOUNTS AND SHOCK. WHEN EVER I DRIVE OVER A BUMP THE RIGHT SUSPENTION SOUND LIKE IT IS GOING TO FALL OUT.
I HAVE CHECKD AND RECHECKED EVERHING IS TIGHT.
ANY SUGGESTIONS?INSIGHT?
PostPosted: Tue Sep 01, 2009 6:32 am
What kind and year of vehicle?
PostPosted: Wed Sep 02, 2009 7:25 pm
Is it a squeak or a thump? Did you make sure you put the washers back on the bolts that go through the upper control arm bushings?
PostPosted: Thu Sep 03, 2009 9:42 am
Check the shock and sway bar mounting points, if loose, they can make a rattling noise over bumps.
