| Front End Noises https://slantsix.org/forum/viewtopic.php?t=36931 |
| Author: | 42willys [ Mon Aug 31, 2009 12:54 pm ] |
| Post subject: | Front End Noises |
HI, COMPLETED A FRONT END DISC BREK CONVERSION FROM A LATER MODEL F BODY. REPLACED ALL THE BEARINGS, DISC, PADS ETC. ALSO REPLACED THE UPPER CONTROL ARMS, BUSHINGS,BALL JOUNTS AND SHOCK. WHEN EVER I DRIVE OVER A BUMP THE RIGHT SUSPENTION SOUND LIKE IT IS GOING TO FALL OUT. I HAVE CHECKD AND RECHECKED EVERHING IS TIGHT. ANY SUGGESTIONS?INSIGHT? |
| Author: | slantvaliant [ Tue Sep 01, 2009 6:32 am ] |
What kind and year of vehicle? |
| Author: | ESP47 [ Wed Sep 02, 2009 7:25 pm ] |
Is it a squeak or a thump? Did you make sure you put the washers back on the bolts that go through the upper control arm bushings? |
| Author: | Doc [ Thu Sep 03, 2009 9:42 am ] |
Check the shock and sway bar mounting points, if loose, they can make a rattling noise over bumps. DD |
