It is currently Mon Nov 30, 2026 7:02 am
 Post subject: Blue smoke
PostPosted: Wed Sep 09, 2009 3:44 pm
I got a big problem I think. My 69 Dart slant six 225 has started emitting blue smoke out the tailpipe. Also Smoke is getting into carb through the top of the valve cover. Air filter will get saturated with oil and the engine will ultimately quit. If I remove the hose from the air cleaner cover, the motor will continue idling but quite a large volume of smoke puffs out. I think it might be the rings are gone but I am not really sure. Any advice would be greatly appreciated. NEED HELP I look like cheech and chong driving down the road.
PostPosted: Wed Sep 09, 2009 4:41 pm
How many miles are on this engine?
It does sound like the engine is worn-out or it has broken a compression ring or 3.
PostPosted: Wed Sep 09, 2009 4:59 pm
If I were in your shoes do a leak down test on each cyl. This will tell you what and which cyl are affected.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Sep 09, 2009 5:28 pm
the motor is original from 69 and has 60,000 miles on it. I will try the leak down test. It seems to me might be easier to get a wrecker motor and do a straight switch rather than getting into doing rings.
PostPosted: Wed Sep 09, 2009 6:08 pm
60K? if that is all-- you need to do some checkiing before swapping motors.
When was the last valve adjustment?
how do the plugs look?
History of the car would help--
How mechanically inclined are you ,Lawrence
PostPosted: Wed Sep 09, 2009 6:37 pm
I have owned the car for ten years. My father was the original owner and purchased it new in 69. I only drive it from may to october, never seen winter. I had a valve job done 5 years/20,000 miles ago. As you can tell this car does much more resting than driving. This is why I am confused, i can't believe all of a sudden it starts doing this. I am going to inspect the valves, lifters and seats tomorrow in the daylight and do a leak down test. Hopefully i can remedy this situation without having to spend a lot of money on a ring job. I don't think i can do the rings on my own.
PostPosted: Thu Sep 10, 2009 5:07 am
If you had a valve job done 20k ago be sure to take a good look at your seals. If they are cheap rubber they might have deteriorated from the long periods of sitting. I guess that wouldn't explain the smoke under your valvecover but you'll know soon enough when you do a comp. check.
-ron
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Thu Sep 10, 2009 12:51 pm
It could be stuck rings. You might want to try some Marvel Mystery Oil in the crankcase and drive it some to see if they loosen up.
Scott M
PostPosted: Fri Sep 11, 2009 5:59 am
dude
you blew the head gasket
even without milkshake
replace it before you cause damage
69 cuda
225 super six
holley 390
offenhauser intake
headers
dual exhaust
