| Need starter help. https://slantsix.org/forum/viewtopic.php?t=37066 |
| Author: | prattwithney [ Fri Sep 11, 2009 10:32 am ] |
| Post subject: | Need starter help. |
Hi i've just finished to rebuilt my engine: - set of valves from EPN, with porting on head -Mopar duster springs -removal of 0.6' to the cylinder head - Clifford four barrel intake - holley 390 cfm - large exhaust. - pertronix ignition But it doesn't start. The starter ( summit 1.9 HP) turn very slowly. May be this starter is not enough powerfull with the new compression ratio ? Or the battery is KO? What do you think ? Thanks Matt from France |
| Author: | Doc [ Fri Sep 11, 2009 11:45 am ] |
Does the engine spin easy by hand, with a wrench on the front of the crank? Was the engine's bottom end rebuild with new bearings? Does the starter spin fast if you test it off the engine? |
| Author: | Davids63Dart [ Fri Sep 11, 2009 4:12 pm ] |
My brother's Duster 440 always cranked slow, and it ended up having 2 spun rod bearings. |
