It is currently Sun Oct 11, 2026 7:03 pm
 Post subject: Need starter help.
PostPosted: Fri Sep 11, 2009 10:32 am
Location: La Milesse FRANCE near the 24 hours of Le Mans
Hi
i've just finished to rebuilt my engine:
- set of valves from EPN, with porting on head
-Mopar duster springs
-removal of 0.6' to the cylinder head
- Clifford four barrel intake
- holley 390 cfm
- large exhaust.
- pertronix ignition
But it doesn't start.
The starter ( summit 1.9 HP) turn very slowly.
May be this starter is not enough powerfull with the new compression ratio ?
Or the battery is KO?
What do you think ?
Matt from France
Dodge dart 270 four door sedan with 170 ci slant.
Video post you tube dodge dart 1965
PostPosted: Fri Sep 11, 2009 11:45 am
Does the engine spin easy by hand, with a wrench on the front of the crank?
Was the engine's bottom end rebuild with new bearings?
Does the starter spin fast if you test it off the engine?
PostPosted: Fri Sep 11, 2009 4:12 pm
My brother's Duster 440 always cranked slow, and it ended up having 2 spun rod bearings.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
