It is currently Sat Jul 18, 2026 6:55 pm
PostPosted: Sun Sep 13, 2009 11:44 am
Made 3 passes at the track today. Started to have hi gear troubles and called it quits. In hindsight, the trans was probably overheated as I made 3 passes almost back to back. After it cooled down it shifted fine for the ride home.
Track conditions DA 1879, temp 73*f
Changes from May. New aluminum drive shaft, 25psi of boost (up 3), replaced 2.94 with 2.76 gear. Still shifting around 4500rpm (In May it ran 12.32@110)
I'll get some vids up later.
Pass 1:
The 215/75r/14 radials heated nicely and it provided a new best 60' of 1.842. As soon as I hit second, the car started to spin the tires hard.
Ran 12.39 @113.65.
Between pass 1&2 a gasser does 180 in my same lane. Decided to try other lane for pass 2.
Pass 2: Good burnout, 1.86 60', car gets sideways as soon as I hit second and abort run. 15.67 @ 89.5mph
Pass 3: Decide original lane was better. Poor burnout but still get a 1.89 60'. I lifted slightly on the 1-2 shift to save the tires. Trans acted funny on the 2-3 (slow & let motor up rev for a split second before 3rd hit) New best for the stock slant 6 12.05et @ 115.59mph
If I had more time and a good trans this combo would have made 11's no problem.
Tom
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Sep 13, 2009 12:49 pm
Still waiting for the outside shot but here is the in car:
http://www.youtube.com/watch?v=VrIjlrQlhkU
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Sep 13, 2009 3:07 pm
Nice work, Tom! Serious MPH. You are starting to approach Ryan's MPH with a 0.3 sec worse 60 ft time.
Is there that much difference in HP between 16-18 psi and 25 psi??
PostPosted: Sun Sep 13, 2009 4:03 pm
Thanks Lou,
The power levels between 18psi and 25psi are almost exponential. Don't get me wrong 18psi feels good but when 25psi hits it is nite and day. The seat dyno can tell the difference.
Tom
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Sep 13, 2009 4:36 pm
Interesting. Tilley said there wasn't much difference in his car above 17 psi or so, at least on his latest incarnation.
Thanks,
PostPosted: Sun Sep 13, 2009 6:29 pm
115 in the traps and it shifted fine on the way home. My kind of guy! Nice work.
PostPosted: Sun Sep 13, 2009 6:34 pm
Close to 100 miles round trip! It was a beautiful day out for a road trip.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Sep 13, 2009 7:38 pm
Tom, What Track Do you run At?
It seems Milan is pretty Close to you. Just wondering,
Good Work!
PostPosted: Sun Sep 13, 2009 7:55 pm
Great work Tom.
I cant wait to get my Supercharged engine off the drawing board and in a car.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Sep 14, 2009 4:38 am
Good Work!
I run at Lapeer Dragway. Its 45 miles whereas Milan is over 70.
Tom
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Sep 14, 2009 8:34 am
Here is the track video.
http://www.youtube.com/watch?v=e53pz9teNTY
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Sep 14, 2009 12:33 pm
Cool.
PostPosted: Mon Sep 21, 2009 10:54 am
Unreal. I sent the clip to the V8 crowd around here. Too bad that wasn't a 12.5 second big block beside the TurboSlant.
'63 Valiant V200 Convertible
225 Aluminum Block
PostPosted: Mon Sep 21, 2009 8:47 pm
FANTASTIC ,so close to the 11s,I can relate,,,,,13.009 Mark
PostPosted: Tue Sep 22, 2009 6:39 am
If i had my best launch of the day it would have been 11.95 to 11.99. How come they never seem to line up?
11.02 @ 120.56
Chassis dyno
