| changing air breather of electronic control fuel system? https://slantsix.org/forum/viewtopic.php?t=37124 |
| Author: | mikk0090 [ Wed Sep 16, 2009 9:04 am ] |
| Post subject: | changing air breather of electronic control fuel system? |
Hello, i just bought a chrome air breather for my 84 ram, it has the electronic fuel system thing on the original air breather, what do i need to do to remove that and just run a regular breather? what do i need to do with the vacuum and electrical lines, do i need to replace the fuel pump? will i gain horsepower from a less restricted cleaner, or lose it from removing the electronic fuel system? any help please? thanks mike |
| Author: | hantayo13 [ Wed Sep 16, 2009 10:06 am ] |
three opitions i can think of: 1 get the earlier electronic ingion and carb 2 find an 85 or later and get the control boxwiring/hoses in under drivers side fender 3 just put chrome cover on keep on roddin' ps sure others will have more |
| Author: | mikk0090 [ Wed Sep 16, 2009 10:33 am ] |
thanks alot for the info, i plan on either super sixin the rod, or 2bbl hurricane intake, and headers later on, should i just wait until then since i wont be running the electronics for the fuel?? |
| Author: | hantayo13 [ Wed Sep 16, 2009 11:13 am ] |
check out articles section Electronic Fuel Injection for the Slant Six also those on supersix keep on roddin' |
| Author: | 6shotvanner [ Wed Sep 16, 2009 12:25 pm ] |
By all means DITCH the leanburn/computer setup,that is IF you can legally do that where you live,ie smog rules and regulations. That being said you would need an earlier dizzy/ecm/ballast/wiring,also an eariler non-feedback carb.If you're going to upgrade to supersix you'll be needing a two barrel carb anyway so might be a good time for that part of change over as well. Best check your smog laws before anything else.The fuel pump shouldn't be an issue,Good luck |
| Author: | mikk0090 [ Wed Sep 16, 2009 8:03 pm ] |
smog isnt an issue, friday im off school, so ill go visit the local grave yard and see about pulling a super 6 setup and rebuild the carb this weekend, will give me something to do |
| Author: | 65Dodge100 [ Wed Sep 16, 2009 10:16 pm ] |
You need this article Danny |
