It is currently Sun Nov 29, 2026 2:08 pm
 Post subject: how much to mill?
PostPosted: Sun Sep 20, 2009 11:33 am
i need to know how much to mill from my cylinder head. i pulled it from a junk car, and my machine shop says it has been surfaced. the problem is we dont know if its been milled, or just surfaced. i cc'ed it and came up with 58cc per combustion chamber. how many cc's can i expect to lose per 0.01"? i'm running mopars mild competition cam, so i know i shouldn't mill too much off, or i might have clearance issues. i would like to end up with 9.25-9.5:1 compression to keep it streetable. thanks for any help!
PostPosted: Mon Sep 21, 2009 2:40 am
Hi,
Welcome - If you use he Search function you will get all the info you need - there is so much on the topic
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Mon Sep 21, 2009 4:40 am
To calculate the compression ratio you need to know not only the combustion chamber size (58cc is close to standard from my experience) but the head gasket compressed thickness and bore, and the engine's bore, stroke and piston deck height. My Valiant's 225 measured out to be 8:1 stock. Another 225 was only 7.7:1.
.0066" off a slant head is 1cc chamber volume.
Mild 225s almost never have valve to piston clearance issues. You'll run out of retainer to guide clearance well before the pistons and valves get close.
PostPosted: Mon Sep 21, 2009 10:03 am
Once you get all of your measurements, the Internet is littered with compression ratio calculators.
Danny
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
