It is currently Sat Sep 19, 2026 5:57 pm
 Post subject: Wheel size
PostPosted: Wed Jun 05, 2002 7:55 pm
Anyone Have any idea on the largest wheel size that will work on a 62 Valiant rear ?
drg2000@optonline.net
PostPosted: Fri Jun 07, 2002 10:38 am
: Anyone Have any idea on the largest wheel size
: that will work on a 62 Valiant rear ?
Are you asking about the largest tire or the largest wheel / rim? What Rim size do you currently have or want to use?
Fitting a larger tire / wheel to any car can be tricky, rim size and off-set is important so please provide more information.
PostPosted: Wed Jun 12, 2002 10:03 pm
: Are you asking about the largest tire or the
: largest wheel / rim? What Rim size do you
: currently have or want to use?
: Fitting a larger tire / wheel to any car can be
: tricky, rim size and off-set is important so
: please provide more information.
: DD
Doc- I was hoping to go w/ centerline 31/2 inch rims on front but I believe they are only available in 15" for small bolt pattern. I was wondering if a 15" rim would work on the rear? Any suggestions you could provide would be appreciated. I checked out your bristol gallery pics which are great, and noticed Oscar Derrick's car. would you know what combination he is using?? -Thanks in advance
PostPosted: Thu Jun 13, 2002 12:28 pm
: Doc- I was hoping to go w/ centerline 31/2 inch
: rims on front but I believe they are only
: available in 15" for small bolt
: pattern. I was wondering if a 15" rim
: would work on the rear? Any suggestions you
: could provide would be appreciated. I
: checked out your bristol gallery pics which
: are great, and noticed Oscar Derrick's car.
: would you know what combination he is
: using?? -Thanks in advance
Dave,
I have a 62 Lancer and the Centerline 3.5 with 165 x 15 on them, If I get a moment I will stick them on my Lancer to see how they fit.
My bet is that you can get these to work in front.
Do you know what off-set and rim width size you have for the rears?
PostPosted: Tue Jun 18, 2002 1:21 pm
: Dave,
: I have a 62 Lancer and the Centerline 3.5 with
: 165 x 15 on them, If I get a moment I will
: stick them on my Lancer to see how they fit.
: My bet is that you can get these to work in
: front.
: Do you know what off-set and rim width size you
: have for the rears?
: DD
Dave,
Almost all of the Slant racers use 15" rims front and rear. You can easily go with a 15X8 as long as you are careful with backspacing and tire size.
Users browsing this forum: Bing [Bot] and 12 guests
