It is currently Sun May 10, 2026 6:04 am
 Post subject: Kelsey Hayes Rotors
PostPosted: Tue Sep 15, 2009 12:50 pm
My old rotors were warped and too thin to machine, so I went looking for new rotors. None of the local parts stores lists them as it's a discontinued item, so I had to order these ones:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
Centric's I believe, are they any good?
PostPosted: Tue Sep 15, 2009 1:35 pm
My local store had them 2 years ago for $26 each. I can check if you like. They are only ok. They have a little warpage. I have not been able to find a rotor in the past year at the local stores that wasn't mfg in china. Pads were still USA.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Sep 15, 2009 4:18 pm
They're on the way, possibly next week sometime... Until then, the beast is out of commission.
PostPosted: Wed Sep 16, 2009 5:29 am
Let us know what you think of them when they arrive.
vm
PostPosted: Sat Sep 26, 2009 6:44 pm
Got the rotors via UPS the other day... Whatever brokerage fees are, it's a scam :evil:
anyways, the rotors seem to be of decent to good quality. A real pain in the ass to remove the old rotors from the hubs and re-install the wheel studs, but a couple hours later and I'm finished the install.
Haven't test driven the car yet, but will update after some spirited braking and water sessions, to see if they warp easily.
PostPosted: Sun Sep 27, 2009 4:39 am
Jester were these stamped as to country of origin? I was told a year ago that they were made in Canada.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Sep 27, 2009 10:09 am
Not sure, but the caliper is thumping against the hub when I corner, so I'll have a look today when trying to fix that :(
PostPosted: Sun Sep 27, 2009 11:30 am
Couldn't find a stamping on the actual rotors, but they were purchased from R1 Concepts and said "replaces Centric xxx.xx".
I pulled the R1 Concept sticker off and the box is stamped "Made in China" :(
PostPosted: Tue Sep 29, 2009 5:04 pm
Oh well. Maybe they will last.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Sep 30, 2009 12:46 am
they seem pretty stout. We'll find out, I guess. :wink:
PostPosted: Sat Oct 03, 2009 3:07 am
I got some from Autozone that were cheap; made in China. They look cheap.
PostPosted: Sat Oct 03, 2009 12:57 pm
:D ah well, at least they're still making them for us. Now try finding a KH hub :|
I'll give a rotor update in the next few month to see if they warp. Next brake job, I'm going with '73+ setup, even if the braking isn't as good, at least those parts are readily available at my local parts store.
