It is currently Sat May 30, 2026 1:00 pm
 Post subject: AM Block?
PostPosted: Wed Sep 30, 2009 7:17 pm
Starting my game plan for a race motor,Have a AM motor I pulled out of my A 100,totally worn out,Wondering the difference from the BH block.Should I start looking for a BH block to build off, or just use the AM block? Will be .104 over and lots of compression.Guzzi Mark
PostPosted: Thu Oct 01, 2009 5:13 am
I don't know what an AM block is. My solution is to not worry about block type. The highest output big bore motors I've seen have been of many different years/types. IIRC, the Drake's 9.85 run was on an early 3-plug block, and Tilley has 3-plug and 5-plug motors making big HP.
Best thing would be to sonic check ifyou are worried about wall thickness.
However, I'm still interested in what an AM block is... I assume this is NOT in Doug's block article?
PostPosted: Thu Oct 01, 2009 5:18 am
Mark
AM block is fine I have 3 that are built and NO problems.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Oct 01, 2009 6:59 am
From the date codes I've seen the AM block is the immediate predecessor to the BH.
PostPosted: Thu Oct 01, 2009 10:36 am
The AM blocks are nice, no problem using one that checks-out. (no core shift, bad corrosion or cracks)
BH blocks have some extra ribbing but I don't think those small, extra ribs add much strength.
