It is currently Fri Nov 20, 2026 9:18 pm
PostPosted: Thu Oct 01, 2009 10:46 am
"On this Hemi block went new MP aluminum heads, which breathe in high octane Sunoco race fuel through one of Barton's hand-picked intake manifolds. A pair of Holley 780s are mounted on top in cross-ram fashion. Once used in the cylinders, the rich smell of that Sun fuel exits into the atmosphere through a Hooker Header/Flowmaster exhaust system that has been given the Jet-Hot Coatings treatment for increased reliability. An MSD ignition and NGK plugs spark the fire with a pair of Turbo Start batteries mounted in the trunk.
Behind the engine is a 904 TorqueFlite built by Pro Trans. It's equipped with a Pro Trans manual valvebody and an 8-inch ATI converter that stalls at 4,500 rpm. A Turbo Action grab handle using an ACD air shifter assures there will be no missing the next gear. The horsepower leaves the driveshaft and goes through a set of Richmond 5.67 gears and Strange components in a 9-inch modular housing before hitting the pavement."
http://www.moparmusclemagazine.com/theh ... parts.html
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Oct 01, 2009 2:30 pm
Yep, it's a Pro Trans hybrid. 727 case with 904 guts. Less rotating mass, but very high maintenance and price. :shock:
