It is currently Fri Nov 20, 2026 5:34 pm
 Post subject: four speed conversion
PostPosted: Fri Oct 02, 2009 5:26 pm
hey guys i need some help i'm building a 73 plymouth duster with a 230 3 speed with floor shift trans.
so first things first
1. will the four speed bolt up to my 3 speed bell housing? (i think they have the same spline)
2. will i be able to use the stock drive shaft?
3.will i need a new transmission mount and cross member
4.what kind of shifters are good to use? i went on summit and all i can find is shifters for a "new process 422" and none for a duster also i want to run a pistol grip shifter
thanks
josh
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Fri Oct 02, 2009 6:21 pm
Your bellhousing may or may not have the 4 speed pattern in it.
Driveshaft should be the same, but you will need a 4 speed yoke.
Mount and crossmember should be the same.
Pistol Grip for a Duster is available from either Brewer's or Passon I believe.
PostPosted: Fri Oct 02, 2009 6:36 pm
what are the bolt spacings for the trans
