| four speed conversion https://slantsix.org/forum/viewtopic.php?t=37354 |
| Author: | theslantingsix [ Fri Oct 02, 2009 5:26 pm ] |
| Post subject: | four speed conversion |
hey guys i need some help i'm building a 73 plymouth duster with a 230 3 speed with floor shift trans. so first things first 1. will the four speed bolt up to my 3 speed bell housing? (i think they have the same spline) 2. will i be able to use the stock drive shaft? 3.will i need a new transmission mount and cross member 4.what kind of shifters are good to use? i went on summit and all i can find is shifters for a "new process 422" and none for a duster also i want to run a pistol grip shifter thanks josh |
| Author: | slantzilla [ Fri Oct 02, 2009 6:21 pm ] |
Your bellhousing may or may not have the 4 speed pattern in it. Driveshaft should be the same, but you will need a 4 speed yoke. Mount and crossmember should be the same. Pistol Grip for a Duster is available from either Brewer's or Passon I believe. |
| Author: | theslantingsix [ Fri Oct 02, 2009 6:36 pm ] |
what are the bolt spacings for the trans |
