It is currently Mon Oct 12, 2026 12:02 am
 Post subject: oil psi sender location
PostPosted: Thu Oct 15, 2009 9:46 am
is there an oil galley plug that can be removed in order to install the compression fitting for a oil psi gauge or do i have to tee into the oil light sender location below the filter?
PostPosted: Thu Oct 15, 2009 10:13 am
If you want the light an the gauge and don't want to drill anything a pipe-T is needed. The hole in the pump body is 3/8" NPT so a reducer bushing will likely be needed for the mechanical gauge connection.
PostPosted: Thu Oct 15, 2009 10:22 am
late 70s and 80s era v-8s and slants often came with a factory pipe-t screwed into the oil pump (slants) or the top rear of the block near the distributor (v-8s). These typically are tapped for the right size fittings to run both a gauge and a light.
Users browsing this forum: No registered users and 16 guests
