| '73 engine into a '63 car, will it work? https://slantsix.org/forum/viewtopic.php?t=37671 |
| Author: | i dig boogers [ Mon Oct 26, 2009 8:49 pm ] |
| Post subject: | '73 engine into a '63 car, will it work? |
ok, so i know anything will work if you put enough money and effort into it, ha. but will it be more difficult than a same era engine swap? any extra parts i would need? thanks, -boogers |
| Author: | SlantSixDan [ Mon Oct 26, 2009 9:24 pm ] |
Not difficult. Use the '63 oil pan and oil pickup and complete engine mounts. If the '63 has an automatic transmission, you will need to use the 1/8" adaptor ring between the small '63 torque converter nose and the big '73 crankshaft counterbore. This can be had from Pat Blais, tflitepatty@verizon.net . Use the '63 carburetor so the throttle linkage will hook up. |
| Author: | Doc [ Tue Oct 27, 2009 8:43 am ] |
I also have the adaptor rings for $20.00 each. PM me if you need one. DD |
| Author: | i dig boogers [ Wed Oct 28, 2009 10:38 am ] |
cool thanks guys. looks like if i use original oil pan and carb, all i need is the 1/8 adapter plate then? i am leaving town tomorrow for the weekend so i wont know if i can get the engine till i retyrn. ill keep you posted. thanks again for the advice/help. |
| Author: | Doc [ Wed Oct 28, 2009 11:44 am ] |
The adaptor is a small, 2 inch ring, not a "plate". DD |
