It is currently Sun Oct 11, 2026 5:59 pm
PostPosted: Mon Oct 26, 2009 8:49 pm
ok, so i know anything will work if you put enough money and effort into it, ha. but will it be more difficult than a same era engine swap? any extra parts i would need? thanks,
-boogers
PostPosted: Mon Oct 26, 2009 9:24 pm
Not difficult. Use the '63 oil pan and oil pickup and complete engine mounts. If the '63 has an automatic transmission, you will need to use the 1/8" adaptor ring between the small '63 torque converter nose and the big '73 crankshaft counterbore. This can be had from Pat Blais, tflitepatty@verizon.net . Use the '63 carburetor so the throttle linkage will hook up.
PostPosted: Tue Oct 27, 2009 8:43 am
I also have the adaptor rings for $20.00 each.
PM me if you need one.
PostPosted: Wed Oct 28, 2009 10:38 am
cool thanks guys.
looks like if i use original oil pan and carb, all i need is the 1/8 adapter plate then? i am leaving town tomorrow for the weekend so i wont know if i can get the engine till i retyrn. ill keep you posted.
thanks again for the advice/help.
PostPosted: Wed Oct 28, 2009 11:44 am
The adaptor is a small, 2 inch ring, not a "plate".
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Plymouth_Ruster and 47 guests
