| Calculating camshaft valve events https://slantsix.org/forum/viewtopic.php?t=37768 |
| Author: | Reed [ Mon Nov 02, 2009 11:46 am ] |
| Post subject: | Calculating camshaft valve events |
I got a cam reground to the specs of an Erson RV10 cam, but the machine shop didn't give me a "cam card" telling me the pertinent valve event times. All I know from the machine shop is the following: Duration @ .050 lift = 212 intake and exhaust valve lift = .435 intake and exhaust valve lash is .012 intake and .012 exhaust I am trying to figure out valve events for purposes of calculating dynamic compression ratio, and I would appreciate it if one of the more knowledgeable beings on this board could double check my math. According to the Erson catalog, the RV10 cam has the following specs: Duration = 254 Duration at .050 = 210 Gross lift = .435 Lobe center = 111 Advance = 4 degrees Valve lash = .022 These are fairly close to what the cam grinder told me, so I will assume that the lobe center and duration figures from the Erson catalog match what I have. So, a lobe separation of 111 degrees and a common duration of 254 degrees for each lobe equals the following valve events IF the cam was installed "straight up" with 0 degrees advance: 16 degree of lobe overlap ([254/2]-111) Intake opens at 246 degrees BTDC (254-[16/2]) Intake closes 8 degrees ATDC Exhaust opens 8 BTDC Exhaust closes 246 ATDC Or, calculating these events @.050 lift: -6 degrees valve overlap ( [(210/2)-111] Intake opens at 213 degrees BTDC (210-[-3]) Intake closes at 3 BTDC Exhaust opens at 3 ATDC Exhaust closes at 213 ATDC Is that right? Now I remember why I switched my major from physics to history...
| Author: | Al T [ Tue Nov 03, 2009 11:04 am ] |
| Post subject: | Here's a pic which might help |
I've just used the advertised duration, numbers, not the lift at 0.050" but you can see how the numbers are built Hope this helps . . . |
| Author: | Reed [ Tue Nov 03, 2009 11:09 am ] |
Yes, it does. Thanks! Looks like if I add the recommended 4 degree advance into my calculations then I got it right. Cool. Good to know I can still do math. |
