It is currently Tue Nov 17, 2026 7:22 pm
 Post subject: 1987 trans plug ?
PostPosted: Tue Nov 10, 2009 1:27 pm
I picked up a 1987 slant six with trans.My question is what are the plugs on it for?I know the first plug from left is the reverse/neutral switch.What is the plug at the rear of pan for?http://i658.photobucket.com/albums/uu31 ... -10004.jpg
PostPosted: Tue Nov 10, 2009 3:00 pm
That's the torque converter lockup wire.
PostPosted: Tue Nov 10, 2009 3:50 pm
Thanks.On my 1982 the lockup is all pressure,no wire.So if I send voltage to that wire lockup will engage?How much voltage?I looked through the sticky pdf on the trans and did not see it.
PostPosted: Tue Nov 10, 2009 4:08 pm
+12v to this wire ought to lock the torque converter.
PostPosted: Tue Nov 10, 2009 4:47 pm
That is what I thought.Thanks again Dan.
