It is currently Wed Oct 14, 2026 3:38 pm
PostPosted: Wed Nov 18, 2009 11:19 am
Power steering pump went on my van and the new one needs the old pulley installed-what's the trick here?looks like a 3/8 allen threaded in to the shaft where my manual and experience tells me that some heat and a 2 jaw puller should work.It won't budge,left handed thread maybe or just a stubborn pulley?any help appreciated
If Ya Don't Get At It When Ya Get To It,You Won't Get To It To Get At It Again
PostPosted: Wed Nov 18, 2009 11:43 am
The pulley is strictly a press fit. I used to sell auto parts and we had a power steering pump pulley remover. You should be able to rent/borrow one from a parts store.
PostPosted: Wed Nov 18, 2009 11:45 am
Probably easier to just go get a new pump from the junkyard.
PostPosted: Wed Nov 18, 2009 4:46 pm
Car Model: 63 Dart 81 D150
With the right tool that is mentioned by Joshie225 it is a real easy job. Without the tool you run a 98% chance of damaging your new pump and voiding the warranty.
TopHat
PostPosted: Thu Nov 19, 2009 4:43 am
TopHat
Correct. Do not "drive" the pulley on the new pump, use a installing tool (usually a long bolt that threads in the shaft, with a nut to draw the pulley on). This is usually included with the new pump.
Bought the tool to remove it and took me 5 minutes after that,I like excuses to buy new tools-Thanxs
Users browsing this forum: Bing [Bot] and 11 guests
