It is currently Mon Oct 12, 2026 10:54 pm
 Post subject: Melling Cam
PostPosted: Wed Nov 18, 2009 4:02 pm
Site Admin
Anybody got a cam card or at least some numbers for the intake event so I can check the cam timing on Linda's engine?
The Melling Cam in question is pn SPD-3 CS-380
Sure would have been nice to get a card with the new cam.... :roll:
CJ
 Post subject: Lol...
PostPosted: Wed Nov 18, 2009 8:49 pm
That's the "stocker" replacement that comes with most of the slant six "master rebuild kits" you get. Last I had checked it's pretty close to the stock 1972+ cam but it had an LSA of 109...none ever came with a cam card...I sold both of the ones I had to people for fresh cam cores to be reground...
:shock:
PostPosted: Thu Nov 19, 2009 4:45 am
Melling SPD-3
From their Camshaft specifications:
IVO: 21 BTC IVC: 70 ABC
EVO: 56 BBC EVC: 24 ATC
@0.06
Duration: 271 Intake, 260 Exhaust
Lift: 0.405 Intake 0.412 Exhaust
Intake C/L: 106
Lobe Sep: 112
Lash: 0.012/ 0.010
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
 Post subject: Wow...
PostPosted: Thu Nov 19, 2009 5:23 am
Intake C/L: 106
Lobe Sep: 112
Wow that's different than the last one I got. 112 is going to keep things really smooth...
PostPosted: Thu Nov 19, 2009 5:40 am
Those figures are at .060 not .050. Right
How much difference will that make???
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Nov 19, 2009 5:56 am
Those must be @0.020" or more likely @0.006" duration numbers. If they were @0.060", then you'd have a ROUGH idle.
PostPosted: Thu Nov 19, 2009 6:46 am
The 0.06 is what the catalog page says, but I suspect it is a typo.
http://users.hal-pc.org/~bwhitejr/melli ... ations.pdf
Page 9.
bwhitejr
0.090 Shaved Head
PostPosted: Thu Nov 19, 2009 3:26 pm
Site Admin
Thanks! :D
I was looking on the Melling web site, but couldn't find technical info...
They sent the specs to me via email today. Looks pretty tame. It's for an around town car, so should be nice and docile.
Here's what they sent me:
DUR.@.050
INT. 198
EXH. 203
Valve Lift
INT. .405
EXH. .412
Lobe Ctr.
INT. 106
EXH. 112
Lobe Sep
109
A little different specification. Still, 109 degrees should be pretty calm.
CJ
Users browsing this forum: Bing [Bot] and 7 guests
