| steel ball? https://slantsix.org/forum/viewtopic.php?t=38009 |
| Author: | dartcustom420 [ Wed Nov 18, 2009 10:16 pm ] |
| Post subject: | steel ball? |
I recently started tearing my 1973 904 apart and when i took the oil pump out a small steal ball bearing rolled out, i read the manual that is linked on this sight and it seems this ball goes on the input shaft kinda shoved in there..and to top it all i lost the ball today |
| Author: | bigslant6fan [ Thu Nov 26, 2009 11:59 am ] |
Did you check the 7 digit part # to be certain it's a "73 trans? I've rebuilt about 20 904s and never had a check ball fall out of a pre-78 non-lock up trans.I took apart a '71 S/6 front pump just to double check before I wrote this,and they DO have two check balls in the rear pump half,but they are staked in very well.I could describe it to you,or maybe photo bucket it to your e-mail,but check those numbers first. |
| Author: | dartcustom420 [ Tue Dec 01, 2009 11:18 am ] |
those numbers were 111-4 |
| Author: | bigslant6fan [ Wed Dec 16, 2009 12:34 am ] |
Doesn't ring a bell,you need the 7 number part#for me to help you |
| Author: | Rug_Trucker [ Wed Dec 16, 2009 6:03 am ] |
The part number is stamped on the pan rail. |
