It is currently Thu Nov 12, 2026 10:09 pm
 Post subject: Lean Burn
PostPosted: Sun Nov 29, 2009 12:32 pm
I have a 1982 D-150 with a slant six and it as the lean burn. I would like to convert it to Elec ingtion. Can I buy a conversion kit for it? Also my carburator is shot and I would like to get one that would go with the conversion kit if possiable.
PostPosted: Sun Nov 29, 2009 1:05 pm
There is no "kit", but you will need to purchase a new carb, new distributor, and a new ignition system. See here and here. Do you have a one or two barrel carb? This will determine what replacement carb you get.
PostPosted: Sun Nov 29, 2009 2:25 pm
Reed is correct in that there is no 'kit' for a slant 6,BUT, there is a 'kit' for v-8 MoPars.I didn't have the benefit of this forum when I converted my 83 leanburn and I do have some non-slant Dodges so I went shopping at Summit.I purchased an MoPar conversion for point type ign systems,used dist in a 360, picked up a proper /6 dist and used the 'orange box',conversion wiring harness and instructions in the 'kit',easy peasy,done.That being said I'm still planning to do the HEI conversion and it would probably be an excellant time for you to just go ahead and Git r done.Good luck :)
PostPosted: Sun Nov 29, 2009 3:36 pm
If you get stuck I have an 82 that I converted to HEI. PM me and maybe I could talk you thru it. It was an afternoon project.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Nov 29, 2009 4:05 pm
Its a 1945 elec bowl vent, single barrel carburator. Would a 1945 with out a elec bowl vent work?
PostPosted: Sun Nov 29, 2009 6:07 pm
Yup on the 1945, so long as the replacement carb has no electronics.
Swapping from lean burn to HEI is EXTREMELY easy, even more so that going from Lean Burn to normal electronic ignition. All you ned to do is wire up the HEI distributor and use the black (+) wire going to the coil as the (+) feed for the relay providing power to the HEI unit. That's it.
PostPosted: Mon Nov 30, 2009 5:50 am
Yep
Its easy. I can even talk him through what wires to connect what to and how to take out or disable the Lean Burn.
Frank
PS Ive also got and 87 that converted to EI
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
