It is currently Mon May 18, 2026 3:01 pm
 Post subject: Tire size suggestions
PostPosted: Tue Dec 01, 2009 10:01 am
So I have a 1968 Plymought Valiant Signet with air shocks on the rear because of major droopage, but not Im tired of looking at the 185 60R13 pizza cutters. Im looking at going up to 14" rims probly the 4.5". Just wanting to know what people think would look good and function well. I was thinking 205 or 215 60R14 front 235 60R14 rear with cooper cobra g/ts. Eventually it will all get upgraded to BBP 15" disc brakes and 8 3/4 rear but for the mean time (2yrs roughly) im going to keep it SBP while its still a /6.
PostPosted: Tue Dec 01, 2009 10:17 am
The tire sizes you have in mind are way too wide for 4½" wide rims. You can run 195/70R14s on them, but even those are a little wide. 185/70R14s fit well on the 4½" wide rims.
It might be wiser to spend money on new leaf springs before changing wheels and tires, though, especially since you have a bigger, more permanent wheel/tire upgrade in mind for the future.
 Post subject: tire size
PostPosted: Tue Dec 01, 2009 9:57 pm
were those old sb rims really that narrow? I thought they started at 5 in and maybe wider later on? Its been a while since I actually looked at one.
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
 Post subject: Re: tire size
PostPosted: Tue Dec 01, 2009 10:33 pm
They sure were.
I ran 215/70R14 BFG Radial T/A's on all four corners on these rims.
PostPosted: Thu Dec 03, 2009 9:30 am
Yep. Mopar used to view tires as something to keep the car off the ground. The 185/70-14 Dan recommends is basically two sizes wider than the stock /6 tire.
BFG and other sites have sections that list the min, max, and recommended rim width for their tires. IMO BFG allows a narrower rim per size than most manufacturers.
The problems with running a tire on a rim that is too narrow are two-fold. 1. The tire has more of a tendency to "roll under" when cornered hard.
2. The bead is pinched which in turn causes the tread to bow up. The result is a wear pattern that looks like the tire is running over-inflated.
The long and the short is that running a tire on a rim that is too narrow creates a situation where the full benefit of the wider tire is not being realized.
You can't fix stupid. - Ron White
PostPosted: Thu Dec 03, 2009 9:32 am
...and even that was only if you paid extra for the optional upgrade! :shock:
Yup…it's one of those "even if you technically can, it doesn't necessarily mean you should" things.
 Post subject: tire size wheel
PostPosted: Sun Dec 13, 2009 5:56 pm
I recently had to take off the old Ansen Sprint 14 by 7 inch wheels with 215-70-14 tires because I just couldnt get them to balance properly.
So I put back on the 14 by 4.5 stock wheels with 185-75-14 tires. I know have a much better balance and can drive high speeds with no problem. I wouldnt put anything bigger than a 185 and those little wheels.
68 dart -4 doors with house paint, dents, satellite radio, and no rust
67 coronet -4 doors, quarter million miles, currently retired and growing older in the yard
73 charger -2 doors big block car, prowls phx in winter, sits inside during summer
PostPosted: Sun Dec 13, 2009 6:07 pm
Tire size calculator and comparer: http://www.1010tires.com/TireSizeCalcul ... ion=submit
