It is currently Sun Nov 15, 2026 4:10 pm
PostPosted: Sun Dec 06, 2009 4:00 pm
Of the automatic transmisson fluids available today,, which would be the correct choice for the automatic trans in a slant powered 68 Barracuda,
This car has been sitting for a long time, what is in it today is likely the original factory fill,,
Also which model transmission would this be?
thanks
PostPosted: Sun Dec 06, 2009 4:19 pm
ATF +4 :?: , and I would guess a 904... You are slant powered, right?
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sun Dec 06, 2009 4:35 pm
Yep, it's an A904. And yep, the premium fluid is ATF+4 (not +3!).
See this post and the post linked from it.
PostPosted: Sun Dec 06, 2009 5:49 pm
thanks,,
yes it is a slant,
does the A904 have much going for it from a durability / performance standpoint,, basically, if I do a mild boost in engine HP,,target 160 to 175 at the rear wheels,, would a good A904 do?
thanks
PostPosted: Sun Dec 06, 2009 5:58 pm
Yes. You aren't going to break it. Just put in good fluid, make sure it's adjusted correctly, and spend upgrade money elsewhere.
