| 68 barracuda auto tranny fluid https://slantsix.org/forum/viewtopic.php?t=38230 |
| Author: | DadTruck [ Sun Dec 06, 2009 4:00 pm ] |
| Post subject: | 68 barracuda auto tranny fluid |
Of the automatic transmisson fluids available today,, which would be the correct choice for the automatic trans in a slant powered 68 Barracuda, This car has been sitting for a long time, what is in it today is likely the original factory fill,, Also which model transmission would this be? thanks |
| Author: | adiffrentcity [ Sun Dec 06, 2009 4:19 pm ] |
ATF +4 |
| Author: | SlantSixDan [ Sun Dec 06, 2009 4:35 pm ] |
Yep, it's an A904. And yep, the premium fluid is ATF+4 (not +3!). See this post and the post linked from it. |
| Author: | DadTruck [ Sun Dec 06, 2009 5:49 pm ] |
thanks,, yes it is a slant, does the A904 have much going for it from a durability / performance standpoint,, basically, if I do a mild boost in engine HP,,target 160 to 175 at the rear wheels,, would a good A904 do? thanks |
| Author: | SlantSixDan [ Sun Dec 06, 2009 5:58 pm ] |
Quote: does the A904 have much going for it from a durability / performance standpoint
Yes. You aren't going to break it. Just put in good fluid, make sure it's adjusted correctly, and spend upgrade money elsewhere.
