It is currently Sun Nov 15, 2026 1:25 pm
PostPosted: Thu Dec 10, 2009 4:51 am
I can't seem to find my reference material and even if I could I don't think it would list this 1977 model transmission. It's behind a standard (not-HP) 360-4 so I believe it's a non lockup A999 and with the standard gearset.
Drivers side pan rail shows 4028435 5697 7047
drivers side mid section 3743036 05305
Thanks!
PostPosted: Thu Dec 10, 2009 8:19 pm
Your right Josh,I can't find the part#either.The date code shows it as a early feb 1977 build date,but it's not listed in my chilton trans book.If the trans and engine VINs match,and your sure it's not a 727,then you lucked into a 999 with all the good stuff. :D Please let me know if you take it apart to confirm it.
