instrument panel voltage regulator
https://slantsix.org/forum/viewtopic.php?t=38278
Author:  echowoods [ Fri Dec 11, 2009 10:19 am ]
Post subject:  instrument panel voltage regulator
question : will a instrument panel voltage regulator from a 64 dart slant six
fit and work properly on a 66 chrysler 300.
are they the same part ? both appear to have three male tabs that fit into circuit board.if not does any body have links to a new one for the 300?
Author:  SlantSixDan [ Fri Dec 11, 2009 10:25 am ]
Answer is "no", because there is no separate external instrument cluster voltage limiter on a '64 Dart — on that car the limiter is built into the temperature gauge. If you have an external voltage limiter marked "64 Dart", it's not marked correctly.
Me, I prefer the solid-state limiter available from R/T Engineering.
Author:  echowoods [ Fri Dec 11, 2009 4:02 pm ]
Post subject:  thanx for link
thanx for link -thats what i was hoping a company was making something
better and more reliable than original limiter. i just ordered one and from the
specs it sound like a great deal -especially if your wiring is a little funky and
old .this limiter may save your gauges if there is a short or other problem
thanx again
Author:  SlantSixDan [ Fri Dec 11, 2009 7:20 pm ]
Yup - that is why I put one of R/T Engineering's limiters on my '71, it is why I've got one (and an upgraded ammeter) on order from them for my '73, and it is why I will eventually have them upgrade the ammeter and rework the limiter for my '62.
Author:  64DartVertible [ Fri Dec 11, 2009 8:46 pm ]
I'm so glad you mentioned those R/T limiters! I did the 5v regulator project after mine went out and smoked my gas and temp gauges. The result is OK but less than good - the gauges take a long time to register when you start the car, and I'm pretty sure they are reading low.
I was going to order one of theirs, but the price was a little high. Do the gauges act normal - quicker and accurate? If they do, I'll go ahead and order one.
Having gauges I don't trust takes away too much fun out of driving the old car. :(
Author:  SlantSixDan [ Fri Dec 11, 2009 8:54 pm ]
Yup — they come up to readings quickly with the R/T limiter.
Author:  64DartVertible [ Fri Dec 11, 2009 9:05 pm ]
OK Dan, you can come clean now....
You get a commission on these things, right? You just sold two of them in less than two hours!!! :lol:
You're a one-man 'economic stimulus plan'... :bow:
Author:  SlantSixDan [ Fri Dec 11, 2009 9:09 pm ]
I wish — if that were the case I wouldn't have had to drop a whack of PayPal cash on 'em for my most recent order! :twisted:
