It is currently Fri May 22, 2026 11:44 pm
PostPosted: Thu Dec 17, 2009 9:17 pm
i snapped2 out of 3 of these. does anyone know where i can get new ones? :?:
PostPosted: Fri Dec 18, 2009 5:03 am
hardware or autopart store...grade 8
PostPosted: Sat Dec 19, 2009 3:13 pm
Just a tip, depending your year and model, you may have to cut longer threads on the grade 8's to mount your accelerator cable bracket. I had to do this once. Grade 8's don't come continuiously threaded from head to foot (or at least I couldn't find them), so an additional inch or so has to be threaded to go all the way through the exhaust manifold. The linkage bracket mounts on the tails of the bolts on the underside of the exhaust mani.
1980 D-150 Slant
PostPosted: Sat Dec 19, 2009 7:56 pm
They do make grade 8 all-thread. The garden variety ones found at your local hardware store are likely grade 2, so make sure you read the label. If it isn't marked grade 8, then it isn't.
Remember, anti-seize is your friend.
PostPosted: Sun Dec 20, 2009 8:38 am
You can use stainless bolts too as an option. That way they don't rust in place. You can also drill out the threads and use nuts on the bolts if the manifold is very rusty.
PostPosted: Sun Dec 20, 2009 9:50 am
Here is a handy bolt head marking chart; Grade-8 bolts have six radial lines on the head.
Users browsing this forum: Ahrefs [Bot] and 19 guests
