It is currently Tue May 19, 2026 7:56 am
 Post subject: Best Gaskets ?
PostPosted: Wed Jan 06, 2010 11:10 pm
Who makes the best gaskets for a slant ?
Mainly oil pump,oil pan,valve cover,fuel pump,etc.
Who makes the best head gasket ?
I have a /6 on a stand,getting ready for a rebuild,and am gathering the parts for it.
Thanks alot.
PostPosted: Thu Jan 07, 2010 2:32 am
The Fel pro Complete engine set works fine in most situations - There are a few options for the Head gasket and intake / Exhaust gaskets, but If it's a stock build fel- pro.
PostPosted: Thu Jan 07, 2010 8:29 am
[quote="Greg Ondayko"]The Fel pro Complete engine set works fine in most situations - There are a few options for the Head gasket and intake / Exhaust gaskets, but If it's a stock build fel- pro.
Greg[/quote]
Thanks Greg,
Planning on bumping up compression by shaving .090-.100 off the head. Just trying to find out what everyone is using ?
Thanks again.
PostPosted: Thu Jan 07, 2010 2:17 pm
Fel Pro will be fine for you in this situation.
PostPosted: Thu Jan 07, 2010 5:27 pm
Thank you.......!
 Post subject: Engine Kit...
PostPosted: Thu Jan 07, 2010 7:15 pm
Shop around a bit, as you can get most of the parts at a reasonable price for the slant from Northern, or PAW, etc... they tend to use Fel-Pro, Melling pumps/parts, etc...
PostPosted: Thu Jan 07, 2010 8:31 pm
Thank you D
Probably pick up Fel-Pro FS7918PT4. Full gasket set.
Rock Auto has it for $71.00
 Post subject: But...
PostPosted: Thu Jan 07, 2010 9:56 pm
I think you get all the gaskets needed for much less of a price with the KS2103 gasket set (at least I've rebuilt engines with them and had plenty of spare stuff from the set....)
PostPosted: Fri Jan 08, 2010 12:34 am
Interesting.......They look like they have the same amount of gaskets.
I wonder if the one has better qualtiy gaskets ?
Pretty sure Fel-Pro has 2 lines.
PostPosted: Fri Jan 08, 2010 1:29 am
There is also a very useful list of parts, including gaskets, in the articles section of the forum: Slant Six Parts List.
Olaf
Aspenized
