It is currently Thu Aug 13, 2026 11:07 am
 Post subject: cast 2.2 pistons.
PostPosted: Wed Jan 13, 2010 8:11 pm
hello. can i use cast 2.2 turbo pistons on a long rod 225 with stock 198 rods? will be a non turbo street build with around .500 lift cam. thanks, andy.
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
PostPosted: Wed Jan 13, 2010 8:19 pm
That specific build is addressed in the articles section.
Hit the home button above, then select articles. Look for "Stroking the Slant Six." It's down that article a bit. :D
PostPosted: Wed Jan 13, 2010 8:20 pm
i was just wondering if the cast piston is sufficient compared to the more expensive forged variety.
PostPosted: Wed Jan 13, 2010 8:35 pm
All cast pistons are not alike.
What type or brand do you have?
In general, a good quality cast piston will be fine for a street engine that is under 10 to 1 compression and kept under 6000 rpms.
No N2O, no boost.
PostPosted: Wed Jan 13, 2010 8:42 pm
thanks, doc. i do not have any yet, would welcome any recommendations on those. i already have the 198 rods, but my budget is very tight. plan on 9.5 comp with no plans for power adders. andy.
