It is currently Sat Nov 14, 2026 1:29 pm
 Post subject: electric fan question
PostPosted: Sun Jan 10, 2010 6:20 pm
After seeing the check that fan message along with the other benifits of using a electric fan i have desided to try one. I was wondering what fan i should use. I would like to use one from a junkyard b/c they are cheaper. Also what would be the best way to turn it on/off other than a toggle switch. any advice would help
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Jan 10, 2010 6:47 pm
Find a car with a radiator and engine close to the size of yours. Get the fan(s) and the shroud and enough of the stock wiring to the fan to get the plug and enough wire to splice into.
You will need to figure out a way to mount the electric fan. Many folks cheap out and just use zip ties (me included).
You will also need some good 10-12 gauge wiring, a quality relay, a temperature sensor, a toggle switch, a coolant temp sensor, some means of mounting the coolant temp sensor, and some good terminals.
You want to mount the fan on the same side of the radiator that it was mounted on the vehicle it was removed from. The coolant temp sensor should be mounted in a position where it will measure the temperature of the engine coolant, preferably in the head, but the coolant cleanout plug on the passenger side of the block or the lower radiator hose might work okay too. The fan should be wired so that it is fed directly form the relay. The relay should get power from the coolant temp sensor and the toggle switch, but the toggle switch should be wired independently of the coolant temp sensor so it provides a manual override.
Good luck!
PostPosted: Sun Jan 10, 2010 7:02 pm
thanks Reed.... will the temp sensor have one terminal or two?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Jan 10, 2010 7:16 pm
Dunno! Probably depends on what model vehicle you get it from.
PostPosted: Sun Jan 10, 2010 10:22 pm
What year?
Early models don't have much clearance between radiator and water pump............
PostPosted: Mon Jan 11, 2010 2:15 am
I mount them with an external trans cooler mounting kit. its basically 4 foam rubber pads and 4 things like zip ties but a little different. I also get a thermostatic controller. it has a temp sensor that I just zip tie to the top of the rad core. you can adjust the temp that triggers the fan. I have had great success with a used 16" pusher from a mercedes.
PostPosted: Mon Jan 11, 2010 6:53 am
I used this fan switch.
http://www.summitracing.com/parts/HDA-3647/
A lot of the moparts crowd are having good luck with the chevy HHR fan as it has a built in shroud. New, they are like something like $65.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Jan 11, 2010 3:00 pm
Its a 85 d100, there is a lot of room. Shaker223 that's exactly what i need. thanks :D
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Wed Jan 20, 2010 1:00 pm
an electric fan from a mid 90's caravan is a nice fit to the stock radiator on my 83 D-150,,single fan with two speeds. The fan assembly from the local pull a part was 15.00.
used an adjustable fan temp switch from Derale,
PostPosted: Sun Jan 24, 2010 5:34 pm
thanks DadTruck i would like to keep this thing mostly mopar
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Mon Jan 25, 2010 12:34 pm
here is a good posting on putting a Caravan fan in a D truck
http://www.dodgetalk.com/forums/showthr ... ectric+fan
got mine from a 94 Caravan, it is a sweet fit. Like the set up in the posting I added a switch for manual control of the fan, and it is also on a thermo switch in the head.
my conversion went a few steps further than the one shown in the article, I also moved the Caravan power control module to the truck, So my fan uses the original three relay set up, I have rewired the module so the other relays will power the head lights, hei, elec fuel pump, ac comp.
PostPosted: Tue Jan 26, 2010 2:08 pm
thats a prety cool setup the fan fits realy good thanks :D
85 d-100 HEI 2BBl
06 Toyota Corrola
